Reggietaylor's avatar
Apr 20, 2022
Nighthawk A1900 R6900v2 loosing connection with devices
Currently running a Nighthawk AC1900 R6900v2 Router with Firmware Version
V1.2.0.62_1.0.1
I have recently started having issues with connected devices loosing connection to the router. The list is long with the devices that are connected.
1 laptop, 2 iphones, 1 PVR 4 camera system (cat5 connection), 3 wireless cameras, probably a half dozen smart plugs, two smart switches, and 4 smart bulbs, 3 firesticks, and 3 Alexa's. Netgear Genie says I have a total of 35 connected devices.
Recently, I have noticed that we are having issues with our Firesticks and iPhones staying connected. Usually only one Firestick is in use at a time. The unused ones are powered down due to being powered by the USB port on the TV itself.
All I have to do is reboot my router and the problem is solved for a couple of days. The strange thing is, we have a range extender in our kitchen so we can have Wifi in our shop. When one of our Firesticks won't connect to the router itself, it will connect to the extender. It's actually farther from the TV than the router itself. Although the signal is weak, we can connect to it when we can't connect to the router itself.
Can anyone tell me why this is happening and is there a way to fix the problem with the constant connection problems? Sometimes I have to reboot 2 or 3 times per week. I am not a router or networking guru so please give it to me in simple terms.
Thanks in advance
  • plemans's avatar
    Are the devices with issues connected to the 2.4ghz or the 5ghz?
    What firmware is on the router?
    What modem/gateway is the router connected to?
    When its having issues, what actual error do you get? Does it connect but say "connected, no internet". Does it disconnect from the wifi entirely? What actually happens?
    • Reggietaylor's avatar
      Reggietaylor
      Guide
      Currently running on 2.4ghz. Some of the smart plugs and smart bulbs will not work if 5ghz is turned on. I had to turn 5ghz off and leave it off to get them set up and keep them working.
      Router Firmware Version V1.2.0.62_1.0.1
      Arris TM1602 Cable modem from Spectrum
      Here's a summery of what I see happen.
      It's mostly with iPhones, laptop, and Firesticks. It also occasionally happens to our Honeywell thermostat too.
      We still have the Wifi connection icon on the screen on our iphones but can't connect to any websites through the browser. In our area, we have no cell service and use Wifi calling and internet.
      Firesticks simply says "no internet connetion" when trying to connect to directly to the router but will connect fine with the range extender, which is a cheap ZettaGuard I got free from Amazon for a review.
      My laptop simply shows a grayed out Wifi indicator with an exclamation mark in it. My laptop does not like the extender. It will connect but the connection is extremely slow.
      When I reboot the router, everything returns to normal. All devices will connect to the router instead of the extender.
      Thanks for taking your time to trying to help me. I am very uneducated when it comes to routers.
      • plemans's avatar
        2.4ghz is a very slow network and sensitive to interference.
        If you're devices have 5ghz, that's what they should be connecting to as its significantly faster and suffers from much less interference.
        Your smart devices shouldn't care if they don't have 5ghz whether its on or not.
        And if they do have 5ghz, they're higher end IoT devices and should connect fine.
        I'd try turning 5ghz back on and select a channel in thee 149-165 range for its channels.
        For your 2.4ghz, try manually selecting a channel on either 1-6-11
