LLEONG's avatar
LLEONG
Tutor
Oct 05, 2015
Nighthawk AC1750 R6700 failure to authenticate for configuration backup
I am getting an authenticate error when trying to backup the configuration on a new Nighthawk AC1750 Model R6700 router.  It has the latest firmware, V1.0.0.2_1.0.1.  A authentication challenge appears and I put the default "admin/password" signon (haven't changed the factory default) but router rejects it.  The challenge box says, "Authentication Required / The server http://192.168.1.1:80 requires a username and password.  The server says: NETGEAR R6700."
Anyone know why this is a problem?
  • Wish I could just close this post.  Found my error.  After multiple failures trying to authenticate (with the wrong password), the Netware Genie will eventually take you to a password reset screen.  Go through the routine and it will reveal to you the correct password.  In my case, it was actually blank because of some attempts I had made earlier to change the admin password...but that's another story.
    • VE6CGX's avatar
      VE6CGX
      Master
      Sorry for the typo. It should read 192.168.1.1:80.
      VE6CGX wrote:
      Tried to log into router using 192.162.1.1:80?
