Santoshroy87's avatar
Jan 07, 2022
Nighthawk AC1750
Since the day I purchased my router (a year before), I have been getting speed around 150 mbps even though I had a plan of 400 mbps from my ISP. All these days I thought the issue was with my ISP.
Recently I added some devices in my home that would need high Internet speed, so I upgraded my Internet plan to 600mbps. But then also I am getting a speed of 150mbps. I called a technician to check the issue and found out the problem is with my netgear router. When directly connecetd to the ethernet, I am getting more than 600mbps speed. I tried updating my router with the latest firmware but I continue to get 150 mbps speed. Can someone please help me on how to fix this issue? Thank you in advance.
Current firmware - V1.0.4.122_10.0.95
  • I was reading some discussion on this forum and found that some of the issues faced by users were fixed by downgrading the firmware to V1.0.3.66_10.0.50
    I did the same and immediately my speed jumped to 350 mbps.
    Is there other ways I can bump my speed to what I pay for ? My Internet plan supports 600 mbps.
    Please let me know. Thank you!
  • plemans's avatar
    You have the R6700?
    What modem/gateway is it connected to
    How are you testing speeds? Wired? wireless
    What device are you testing on?
    If you have qos, traffic monitoring, parental controls, or access control enabled, disable them and reboot the router.
    Those services require packet inspection and the R6700 doesn't have the cpu to do packet inspection above certain speeds.
    • Santoshroy87's avatar
      Santoshroy87
      Guide
      You have the R6700? - Yes
      What modem/gateway is it connected to - Netgear CM100 Multi-Gig Speed cable modem
      How are you testing speeds? Wired? wireless  - Wired (~750 mbps) Wireless (~250 mbps)
      What device are you testing on? - Tested wireless using speed test app on my iphone as well as desktop
      If you have qos, traffic monitoring, parental controls, or access control enabled, disable them and reboot the router. - all are disabled.
      Please let me know if you need any other information.
      Thank you for your help.
      • erlerjr's avatar
        erlerjr
        I'm in the same boat and have been reading a lot of threads with a similar problem but not finding any good resolutions so will be following in case you hit upon what is needed!
        Quick question: How were you able to downgrade your firmware to V1.0.3.66_10.0.50? I did a factory reset last night but it just reset back to V1.0.4.122_10.0.95.
        Just changed our ISP from Xfinity to RCN and am supposed to be getting 1gig speeds. When I plug ethernet cable directly into computer we get around ~800mbps but speed tests over Wifi are only getting around ~200mbps.
        So, probably a similar setup.
      Santoshroy87
      Guide
      Hi there.. sorry to reach out to you again, just checking if you were able to see my response to your question. I am still facing the speed issue and if you can help me further, it will be really helpful to me.
      Thank you once again.
  • michaelkenward's avatar
    michaelkenward
    It might help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
      Santoshroy87
      Guide
      Yes it does have a modem - Netgear CM1100 multi gig Speed cable modem
      It is only a modem and doesn't have a router.
      Please let me know if this answers your question.
      Santoshroy87
      Guide
      Hi.. sorry to reach out again, just checking if you were able to see my response to your question and if you can help me further..
