RussF57
Dec 17, 2018Aspirant
Nighthawk AC2300 R7000 - should antennas be returned with an approved RMA?
Are the detachable antennas considered part of the router or are they considered "accessories"? I am not sure if I should pack it with the router for RMA. The instructions on the return policies page did not specify. I understand that we should not include cables, wall bracket and power supplies.
Thanks.
Greetings,
The antennas are not considered accessories. You typically keep everything except the router and antennas, even if they can be detached.
Greetings,
- RussF57Aspirant
Thanks for your help !
Russ
