art4mad's avatar
art4mad
Nighthawk and Xfinity Modem- No Internet?
I just got a Nighthawk X6S AC4000 router to replace my aging Apple Airport Extreme network, Modem has been set correclty to bridge mode and the radio deactivated, and the Extreme has been our wifi router with some devices directly wired to it as well. I tried to replace the AE with the Nighthawk, but the router would not relay the internet signal. Devices coould connect to the Nighthawk via WiFi and I had one computer wired in with ethernet as well. No internet access either way. The internet light on the Nighhawk is white and stable, indicating successful internet connection, but it is not being passed on to any connected devices. I was able to directly plug a laptio into the modem and got internet instanly, so the modem is working fine. I was also able to reconnect the AE network and that router does fine.
I tried rebooting both the rouer and the modem severla times in different order. Sam issue. Cannot figure out what the problem.
  • Thanks. After scouring the web for a possible solution and playing with various MAC addresses I just kept rebooting the modem and the router back and forth until it suddenly worked. No rhyme or reason to it, but something clicked somewhere. Sorry I know that does not help someone else who may have the same problem.
  • Hi art4mad,
    What is the IP address of the router when connected to the modem? Compare to the IP of the laptop when connected to the modem if the same.
    • JamesGL's avatar
      JamesGL
      Master
      Hi art4mad,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      • art4mad's avatar
        art4mad
