SntaCruz83's avatar
Mar 15, 2018
Nighthawk Guest Network Limitation
Nighthawk R7000
Firmware Version
V1.0.9.18_1.2.27
I wanted to set up some IP cameras and other devices on a guest network that wouldn't have access to my actual local network. However, it seems like my only option is to "Let devices see each other and allow access to my local network." I need them to be able to see each other to work, but I don't want them to have access to my local network.
I've gotta be missing something because this kind of kills a lot of the advantages one would hope to get when using a guest network. As it is, it's not really a "Guest Network."
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi SntaCruz83,
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
  • JamesGL's avatar
    JamesGL
    Hi SntaCruz83,
    Yes, that is the only option it has. Once enabled, devices connected to the guest network will have access to local network.
