Ultra-Giraffe
Apr 12, 2017Aspirant
Nighthawk R6700 5G radio not working after firmware upgrade
Netgear Nighthawk R6700 that I just upgraded to firmware V1.0.1.20_10.0.3. It seems to have killed the 5G radio. I have confirmed with a wifi environment analysis utility (Mac OS "WiFi Explorer" ap...
- Apr 23, 2017
Hi Ultra-Giraffe,
Try to observe the 5GHz connection. If it is stable now, try to reload the latest firmware. Reset and reconfigure. If it is not stable with the current firmware that is loaded on the router, I would suggest contacting support for possible replacement. Check with them the warranty of your device.
Ultra-Giraffe
I should add that the router web interface shows the 5G wifi zone as enabled and working normally.
