Fiskars
Dec 05, 2021Aspirant
Nighthawk R6700V2 repeating function
Nighthawk R6700V2 Router
Firmware V1.2.0.88_1.0.1
The knowledge base article refers to the screen captured in the attached as having a Repeating Mode
7. Select Advanced Setup > Router/AP/Bridge/Repeating Mode.
8. Select Enable Wireless Repeating Function for the 2.4GHz or 5GHz WiFi band.
Other threads have brought this up, but I didn't see a solution. A screen shot was requested, but not provided that I can see. Attached is my screen shot.
I have two R6700V2 routers. One downstream from the other. I want them to act as one network so that devices in my garage seemlessly see devices in my house. There is ethernet between the routers.
- FiskarsAspirant
Apparently the screen capture I upload got removed. Bottom line is that it includes Router Mode, AP Mode, and Bridge Mode... but no Repeater Mode.
I didn't see in the manual that the V2 of the R6700 had a repeater/extender mode. And the knowledge article no longer shows the "applies to" for routers.
How do I enable the extender mode feature on my Nighthawk router? | Answer | NETGEAR Support
If it ever had the mode, it might have been removed in newer firmware.
If thats the case, you could try downloading.
Or it might not have ever had that mode. It might have been something in V1 or V3 of that hardware.
- FiskarsAspirant
Is there another approach to making the downstream router extend the network?
Currently it is a separate network with identical wifi names. It works for most applications, but some things can't see devices on the other network.
It may be some time before images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
With a wired link between two routers the most obvious solution is to put the second one in AP mode.
More reliable, easier to set up and faster.
