davedave90
Sep 16, 2020Follower
Nighthawk R6700v3 - Whatsapp calls won’t connect
Hey everyone, I’ve seen over 100 posts about this but not a single solution. I just got this router. Everything works well except Whatsapp. I’m using iPhone 11 and every time I make voice or video c...
Dapsylaw
Feb 16, 2021Aspirant
Hi all,
I am having problems receiving WhatsApp calls. The calls keep reconnecting and sometimes it just says poor signal and doesn’t work. The problem is with the R7000. I am surprised because I use Verizon Fios (fiber) and my speed tests reach 300 MBPS. The outgoing WhatsApp call are fine just the incoming calls have issues. When I switch from WiFi to Cellular it works well. I think Netgear should resolve this problem as I am not the only one complaining. Thank you.
Ola
Ola
Dapsylaw
I found out the problem is with IPhone. You need to go to your settings-WhatsApp-then enable local network for WhatsApp.
