davedave90
Sep 16, 2020Follower
Nighthawk R6700v3 - Whatsapp calls won’t connect
Hey everyone, I’ve seen over 100 posts about this but not a single solution. I just got this router. Everything works well except Whatsapp. I’m using iPhone 11 and every time I make voice or video c...
Dapsylaw
Feb 15, 2021Aspirant
I found out the problem is with IPhone. You need to go to your settings-WhatsApp-then enable local network for WhatsApp. This should work
- Phi2bonnetJul 18, 2022AspirantHey
Any idea where to solve the same issue on Android WhatsApp? I didn't find the place to allow the network to run
Thanks
