NormS1
Jun 04, 2021Follower
Nighthawk R6900P Router
Hello, Anyone know where to get the Nighthawk app. The only place I have found it is on Google. Blocked from Google. Long story, not worth reading. You would think Amazon would provide it since they ...
Jun 04, 2021Guru - Experienced User
Reason you need the app?
You can change settings using the browser
