dep0we
Nov 02, 2016Follower
Nighthawk R7000 + Nest Cam
I'm attempting to get my Nest cam to work with the IFTTT app and/or LIFX lights. Nest has direct integration with both products. However its not working properly. Nest provided me the following to...
- Nov 03, 2016
Hi dep0we,
Connect the device directly to your modem and check the ports. If close, contact ISP to unblock the ports as they might be the one blocking the ports.JamesGL
Community Team
JamesGL
Nov 06, 2016NETGEAR Employee Retired
Hi dep0we,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
