Roadturn
Feb 13, 2016Tutor
Nighthawk R7000 and Centurylink Actiontec C1000A
This router worked great with my cable modem service. After switching to Centurylink DSL, though, it's not performing well at all. Running straight from the Actiontec C1000A output to the interne...
- Feb 13, 2016
It will do it, I have a C1000A, C2000A and C2000T... so from experience. I hope that helps, if not we will try something else :). I currently use bridge mode, with my C2000T.
Infact here are the instructions for Transparent Bridging from CL itself:
http://internethelp.centurylink.com/internethelp/modem-c1000a-adv-bridging-q.html
Roadturn
Feb 13, 2016Tutor
Avtella, I know enough to sort of understand what you're saying. Let me see if I the Actiontec will set to bridge mode first. I don't think it will, but I'll try.
Roadturn
Feb 13, 2016Tutor
Well, I was able to switch the Actiontec to transparent bridge mode. Now I have no internet at all via Centurylink... whoops.
- avtellaFeb 13, 2016Prodigy
After setting the C1000A to bridge mode you need to switch your connection type to PPPoE in the R7000 and enter your CenturyLink username/password and also set dailing option to always on.
Here is an image from my router for example:
