Roadturn
Feb 13, 2016Tutor
Nighthawk R7000 and Centurylink Actiontec C1000A
This router worked great with my cable modem service. After switching to Centurylink DSL, though, it's not performing well at all. Running straight from the Actiontec C1000A output to the interne...
- Feb 13, 2016
It will do it, I have a C1000A, C2000A and C2000T... so from experience. I hope that helps, if not we will try something else :). I currently use bridge mode, with my C2000T.
Infact here are the instructions for Transparent Bridging from CL itself:
http://internethelp.centurylink.com/internethelp/modem-c1000a-adv-bridging-q.html
avtella
Feb 13, 2016Prodigy
In the R7000 Internet settings do as follows:
Change does Internet require login to yes.
Change Internet Service Provider to PPPoE
Enter CenturyLink provided login/password
Leave Service Name empty
Set Connection Mode to always on
Roadturn
Feb 13, 2016Tutor
That's the configuration. No internet.
