Roadturn
Feb 13, 2016Tutor
Nighthawk R7000 and Centurylink Actiontec C1000A
This router worked great with my cable modem service. After switching to Centurylink DSL, though, it's not performing well at all. Running straight from the Actiontec C1000A output to the interne...
- Feb 13, 2016
It will do it, I have a C1000A, C2000A and C2000T... so from experience. I hope that helps, if not we will try something else :). I currently use bridge mode, with my C2000T.
Infact here are the instructions for Transparent Bridging from CL itself:
http://internethelp.centurylink.com/internethelp/modem-c1000a-adv-bridging-q.html
avtella
Feb 13, 2016Prodigy
In the R7000 Internet settings do as follows:
Change does Internet require login to yes.
Change Internet Service Provider to PPPoE
Enter CenturyLink provided login/password
Leave Service Name empty
Set Connection Mode to always on
Roadturn
Feb 13, 2016Tutor
Internet Connection Status shows Not Connected (and won't connect)
- avtellaFeb 13, 2016Prodigy
PM me screenshots of your C1000A WAN/DSL transport settings and R7000 Internet/WAN settings as well.
Be sure to blackout any usernames/passwords/MACs/SSIDs.
Also I assume you entered the full user id as in inclding the @centurylink.com or qwest.net etc
Ok, I got your E-Mail, looks like the router is setup fine, guess we have to check the modem settings.
Once again remember you must enter your full id ie: [email protected] or [email protected] depending on your area.
