Roadturn
Feb 13, 2016Tutor
Nighthawk R7000 and Centurylink Actiontec C1000A
This router worked great with my cable modem service. After switching to Centurylink DSL, though, it's not performing well at all. Running straight from the Actiontec C1000A output to the interne...
- Feb 13, 2016
It will do it, I have a C1000A, C2000A and C2000T... so from experience. I hope that helps, if not we will try something else :). I currently use bridge mode, with my C2000T.
Infact here are the instructions for Transparent Bridging from CL itself:
http://internethelp.centurylink.com/internethelp/modem-c1000a-adv-bridging-q.html
Roadturn
Feb 13, 2016Tutor
Internet Connection Status shows Not Connected (and won't connect)
avtella
Feb 13, 2016Prodigy
Ok, I got your E-Mail, looks like the router is setup fine, guess we have to check the modem settings.
Once again remember you must enter your full id ie: [email protected] or [email protected] depending on your area.
