Cosmro's avatar
Cosmro
Nighthawk R7000, Blinking Internet LED with connected ethernet cable, no WI-FI and internet access
Hello, long story short, I tried logging into my router with admin and password but it kept going to the Password Recovery page but whenever I enter the right serial number several times, the continue button was always grey and I couldn't do anything. I looked up solution and one solved post said to use the 30 30 30 reset method. I tried to reset, then when I was done it wouldn't connect to the internet anymore so I treated it like a new router, I rebooted the modem, then connected the ethernet cables. Now for some reason the power is on but the internet LED keeps blinking white for a long time with no WI-FI and no internet access, the modem LED lights are completely fine as well. I tried multiple times and can't seem to find any solution no matter where I look, I have to use my mobile phone with my 4G network to actually find a way through this.
  • Cosmro's avatar
    Cosmro
    Jun 13, 2018
    Sorry for not replying in three days, I wanted to take a break from the situation but I just fixed the router miraculously. The main problem was that the DHCP was not enabled for "Wi-Fi" and it took one click to solve the whole problem. Thank you for your time in helping.
  • michaelkenward's avatar
    michaelkenward
    Cosmro wrote:
    Now for some reason the power is on but the internet LED keeps blinking white for a long time ....
    This is a sign that your router is trying, and failing, to connect to your modem.
    First check that the modem is working as expected and has established an internet connection.
    As you have been playing around with things on your network, you should also reboot the whole thing in the right order.
    • Turn off and unplug the modem.
    • Turn off the modem router and computers.
    • Plug in the modem and turn it on. Wait 2 minutes.
    • Turn on the modem router and wait 2 minutes.
    • Turn on the computers.
    If that does not work come back with details of the modem at the front of this network.
    • Cosmro's avatar
      Cosmro
      It's a Technicolor TC8717T Docsis 3.0 Wireless Telephony Cable Modem
      All LED lights are lit up on the modem with no constant blinking
      I have tried out the method and I cannot recieve any connection and the light remains blinking
        michaelkenward
        That looks like a modem-router. The clue is the stack of LAN ports on the back.
        This means that you are trying to set up two routers on your network, which is a recipe for chaos.
        Your best bet is to work out how to put the Technicolor TC8717T into "modem only" (bridge) mode or, if that is not possible, use the R7000 as an access point.
