Pops109
Feb 20, 2022Aspirant
Nighthawk R7000 blue light not connecting to Wi-Fi
All of a sudden my R7000 has all blue lights and does not connect to the internet. Unfortunately I am not at the location where the router is located. Each morning I have it set, using a 24 hour timer, to turn off for 15 minutes and then turn back on. It was worked without any problems since October 2021. About a week ago, I no longer can access any of my smart devices, (switches, cameras, etc.). I had a friend, who is local to where it is, check it out. He sent me a photo showing all lights are blue. I had him reboot the Optimum modem and reboot the R7000 about five times and still no internet connection. Blue lights remain.
Any help would be greaterly appreciated.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
Actually these LEDs are WHITE.
The Intternet globe LED next to the power LED would be Amber if there wasn't a good connection with the ISP modem.What Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- Pops109Aspirant
Thank you for such a quick and detailed reply.
Unfortunately i do not know the firmware version. I believe it was up to date as of October, 2021 which was the last time I was physically at the location where it is.
The Modem is: UBee or ARRIS. I do not know the model number
The computer has not been turned on since late October.
My friend did turn unplug the modem then the router, Waited over a 30 minutes, then reconnected modem then router.
The computer has not been turned on. All other devices (cameras, plugs, Rings, Nest, etc.) are always on.
I don't know what else to try.
- Pops109Aspirant
My ISP says the modem is working fine and sending a signal to the router. If all the lights are supposed to be white ( not blue) then why are all my smart devices not connecting to the internet? Not one works.
