Jammers
Sep 23, 2014Tutor
Nighthawk R7000 vs R8000
I'm looking for a new ac wireless router and want to know which of these models is the best. What are the pros and cons of each router?
- Sep 27, 2014Well i just pulled the trigger on the R7000. Usually i go for the latest and greatest but it sounds like the R8000 still has some bugs to work out and the R7000 more then meets my needs. :)
Retired_Member
Sep 23, 2014You might try searching on this subject. I believe one or more threads are already started.
The short answer is the r8000 offers two 5g radios so if you need that option choose the r8000 if not then the r7000.
