Jammers
Sep 23, 2014Tutor
Nighthawk R7000 vs R8000
I'm looking for a new ac wireless router and want to know which of these models is the best. What are the pros and cons of each router?
- Sep 27, 2014Well i just pulled the trigger on the R7000. Usually i go for the latest and greatest but it sounds like the R8000 still has some bugs to work out and the R7000 more then meets my needs. :)
sutedy
Oct 02, 2014Guide
Jammers wrote: Well i just pulled the trigger on the R7000. Usually i go for the latest and greatest but it sounds like the R8000 still has some bugs to work out and the R7000 more then meets my needs. :)
If I were you, I will neither buy R8000 nor Asus RT87U.
Do not believe 4x4 MU-MIMO will solve your busy WLAN problems as up to today there's none of AC client adapter supports this (max 3x3).
http://www.smallnetbuilder.com/wireless/wireless-reviews/32518-netgear-r7500-nighthawk-x4-smart-wifi-router-reviewed?showall=&start=4
