Jammers
Sep 23, 2014Tutor
Nighthawk R7000 vs R8000
I'm looking for a new ac wireless router and want to know which of these models is the best. What are the pros and cons of each router?
- Sep 27, 2014Well i just pulled the trigger on the R7000. Usually i go for the latest and greatest but it sounds like the R8000 still has some bugs to work out and the R7000 more then meets my needs. :)
Redtulips7
Oct 08, 2014Luminary
sutedy wrote: Can you post your result?
result???:confused::confused::confused:Am I taking exam here?
