ALFY_NET's avatar
ALFY_NET
Nighthawk R7000P in access mode only accepts 2 devices
Hi,
I have this router configured as "access mode" because I need to access devices connected to this wireless router, my firewall is providing ip addresses through firewall dhcp and 20 IPs are available.
It seems that if I connect more than 2 devices and try to connect a third one then will disconnect one of the 2 devices.
I would like to know if there is a way to fix this issue? I am running the latest firmware 7000P-V1.3.3.154_10.1.86, I don't want to configure it as router mode.
Please advice
  • michaelkenward's avatar
    michaelkenward
    What is that "firewall"? These don't usually handle "routering".
    In AP mode, the R7000P hands most things over to the router that sits between you and the Internet. What is the modem/ONT/gateway/router or whatever it is that handles the traffic?
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    • ALFY_NET's avatar
      ALFY_NET
      I have a Cisco ASA in front of the Nighthawk and has dhcp enable with 20 ip addresses available.
        michaelkenward
        You may have to explain how that fits into the network.
        Netgear's routers are designed to sit behind a modem of some sort or, in AP mode, behind a router.
        The circumstances you describe seem to be rare. Anything that has appeared might be here:
        Search - NETGEAR Communities – cisco asa
        It might also make sense to ask Cisco how you are supposed to attach things to its hardware.
