Shirox's avatar
Shirox
Nighthawk r700p drops 5G network
So today out of no where my Nighthawk r7000p 5g network stopped working on all my devices connected to the 5G. I went into the nighthawk app thinking I may have accidently turned it off or something but its still showing as on, even checked the physical router and it shows its on. My devices can not find or manually connect to the 5G now. I have tried to do the routerlogin to run troubleshooting that way but it will not connect at all even after doing cache clear and the troubleshooting for it. I have no idea what to do now to get the 5G back to working.
current firmware on the device is V1.3.1.64_10.1.36 via the nighthawk app.
  • the newer version of firmware is out. Its version 1.3.2.134
    I'd highly recommend against updating via the app. Its supposed to be all hosted on the router but when I've seen corrupt firmware issues, its tends to be when done via the app.
    So try installing it over a hardwired connection. then do a factory reset and clean install (not from a backup configuration).
    See if that helps.
    Nighthawk R7000P | AC2300 Smart WiFi Router | NETGEAR Support
  • michaelkenward's avatar
    michaelkenward
    I assume that you have tried a network reboot. (You don't say.)
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it to connect.
    • Turn on computers and rest of network.
    It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    • Shirox's avatar
      Shirox
      I have tried that shortly after posting and had no change. the router is right next to my modem ive not had any issues with it until literally last night after 11 months of having this in the same spot.
      • plemans's avatar
        See if that helps.
