kevinluebke's avatar
Feb 13, 2023
Nighthawk r7350 Timing Out Alexa from Yamaha Soundbar
Firmware version 1.2.0.88 using app on Iphone XR 16.2
I have a Yamaha YAS 209 that uses Alexa.  Ever since installing my Nighthawk Router, the Alexa feature on the Yamaha app always times out before allowing access. I have reached out to Yamaha on several occasions, and they even sent me a replacement sound bar.  Same results. I took the soundbar to a different network that uses the same modem, but doesn't use a Nighthawk router, and it connected to Alexa right away.  Yamaha is telling me that something in the Nighthawk router is preventing the connection to Alexa/Amazon.  I have reset the entire network multiple times, and even reset the router to factory settings.  Any suggestions as to a possible solution would be greatly appreciated.
Thanks for your time,
Kevin
  • plemans's avatar
    What modem/gateway is the router connected to?
    Are you making sure your phone you're using for the setup is connected to the R7350's 2.4ghz network?
    • kevinluebke's avatar
      kevinluebke
      Guide
      It is a Spectrum DOCSIS modem, and yes to the 2.4. The soundbar will only operate on 2.4.
      • plemans's avatar
        What spectrum modem is it?
        Did you manage to get it setup but its timing out while using it?
        Or timing out during setup?
        Is ipv6 enabled?
