Retired_Member's avatar
Retired_Member
Nov 05, 2017
Nighthawk r7500 vpn setup
I'm new to VPN but learn quickly. I'm trying to setup VPN on my router for a layer of security for my home. I am getting error messeges with openVPN. Following the instructions on the router, many forums, and the OpenVPN resources, I am not able to get this working. I receive this error "warning: no server certificate verification method has been enabled. see http://openvpn.net/howto.html#mitm for more info." can someone please assist? Perhaps have a walk through other than what's just on the router? Thank you in advance.
  • Retired_Member's avatar
    Retired_Member
    Nov 08, 2017
    After reading a LOT of information I decided to sell my R7500 and buy a R7000P  I flashed it with DD-WRT and was done in about an hour...  Super easy.  I'm not sure why Netgear does not have more functionality built in the standard interface.  Thank you all for the replies.
  • We probably need a bit more info to really help you, but I've set up the VPN server on both the 7000 and 7500 routers, using both stock Netgear firmware as well as Tomato and DD-WRT 3rd-party firmwares. Netgear makes it fairly easy in the stock firmware, especially if you're just using a mobile device/smartphone. So what is the client device, do you already have a dynamic DNS provider for your ISP's internet connection (Netgear has the stock one I think serviced by No IP so you can choose a subdomain in the "mynetgear.com" DNS zone).
    In Advanced > Advanced Setup > VPN Service > Enable VPN Service, I choose UDP for both TUN and TAP modes using the default ports 12973 and 12974, and I choose to forward all sites on internet *and* LAN through the VPN for maximum privacy when using the VPN on a public wi-fi AP.
    Once those settings are applied, click the "For Smart Phone" button to download the OpenVPN (.ovpn) file--if you're on your phone already, just save this somewhere (locally, cloud storage, etc.) for access momentarily, & if you're on a desktop computer, you'll need to save it and then transfer it to your phone by whatever means necessary.
    Next, install the OpenVPN app on your mobile device, after which you'll copy or import that .ovpn file on the phone into the OpenVPN mobile app. In iOS, this can be done through the shart sheet menu, selecing copy to OpenVPN--for example, if the .ovpn file is in Dropbox, select it and select share extension > copy to OpenVPN. OpenVPN app should ask you to confirm the import by hitting a green plus button, if my memory serves. Once imported, you can test it by tapping the toggle in the app to connect to the VPN. At this point, the VPN profile will have also been adding into your Settings app under the VPN section, so you can toggle it on/off there OR from the OpenVPN app.
    Doing this on a desktop OS is roughly similar.
    • ClarDold's avatar
      ClarDold
      Apprentice
      I just bought a Netgear R7000P (Firmware Version V1.2.0.22_1.0.78) to replace an Asus RT­N56U.
      That router never had good wifi range, and after two years, the 5GHz connection would just die, and I needed to reboot regularly.
      But, the VPN seemed better to me than the OpenVPN on the R7000.
      On the R7000, it seems that port 80 is open to the world as soon as you enable VPN.  I don't like that.
      On the R7000, there is only one login, admin?  Is that correct?
      On my Asus, I had separate long user names and passwords for each VPN user.
      I don't understand having every user log in as admin, and therefore allowing every VPN user full admin access.
      Can I control what IP addresses or subnets can access port 80?
      If I deliver the "smartphone.zip" file via some method, does port 80 have to be used at all?
      If I deliver the zip file, do they ever need the admin login?
      I think I only need TUN, but I see no way to disable TAP.
      I will be using primarily an iPad into my VPN, often an Android phone, occasionally Windows and Mac.
      • bripab007's avatar
        bripab007
        Tutor
        I'm not sure what you mean by port 80 being open to the world when you enabled the VPN server. When it's enabled, it'll listen on port 12974--if memory serves--for incoming VPN client connections. I also am not quite sure what you mean by one admin login for the VPN. Your old Asus router likely used an older PPTP VPN server with simplistic un/pw combos as the only method for logging in. The OpenVPN server on the Netgear routers uses client certificate chains (i.e. the .ovpn file you download from the GUI after turning it on). Yes, the Netgear implementation only lets you create a single .ovpn file, and thus, only a single discrete client, but you can connect I think up to two or four VPN clients with that cert on the R7000 (I think the R7500 supports four or eight??). Again, I'm not sure what you mean by VPN user having full admin access--the point of the VPN is to get a remote client onto your LAN, nothing to do with admin permissions. I think most mobile clients use TUN and desktop OS clients like Windows use TAP.
      Retired_Member
      I am setting this up on a PC connected to the router in hopes to have the entire network using the VPN tunnel.  I am on Win 10 and have performed these steps to a tee:
      Step 1: Select the Enable VPN Service check box and click the Apply button.
      Step 2: Download the client utility from http://openvpn.net/index.php/download/community-downloads.html and install it on the devices where you want to run the VPN client.
      Currently IOS and Android clients are not supported.
      Step 3:
      Click the proper button below to download the configuration files for your VPN clients.
      For Windows For non-Windows
      Step 4: Unzip the configuration files you have just downloaded and copy them to the folder where the VPN client is installed on your devices. For a client device with Windows 64-bit system, the VPN client is installed at "C:\Program files\OpenVPN\config" by default.
      Step 5: For a client device with Windows, you need to modify the VPN interface name to "NETGEAR-VPN". The VPN interface usually has a Device Name as "TAP-Windows Adapter".
      Step 6: Client utility must be installed and run by a user who has administrative privileges.
      Step 7: For help connecting using OpenVPN clients, please refer to http://openvpn.net/index.php/open-source/documentation/howto.html#quick
      Note: if you want to make any change in Advanced Configurations section, please make the changes before you download the configuration files in Step 3.
      Service Type UDP TCP
      Service Port
      12974
      Clients will use this VPN connection to access _Auto _X_ All sites on the Internet & Home _Network Home Network only
      At this point I have the following installed in the OpenVPN config dir:
      ca.crt
      client.crt
      client.key
      client.ovpn
      I run the gui interface with admin privs and get this message every time:
      Mon Nov 06 22:45:30 2017 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
      I am just trying to set this up as a client letting the server do it's thing.  What am I missing here?
        bripab007
        Tutor
        I believe the Windows VPN client needs to be TAP, so you have the VPN server set to TAP on the router, right?
        Searching that error seems to bring up a host of different problems/suggestions on the web.
        One thing you could try is using a consolidated .ovpn file that contains all the necessary certificates embedded inline in the body. I've had good luck with those, rather than the separate client, server, certificat authority, key, etc. cert files. http://permalink.gmane.org/gmane.network.openvpn.user/32469
