jahn28
Mar 21, 2019Tutor
Nighthawk R7500v2 Constantly Restarts
Router Hardware:
Nighthawk X4
AC2350
Model # R7500V2
Firmware: 1.0.3.40
Link: https://www.netgear.com/support/product/R7500v2.aspx
Modem Hardware:
CM700 High Speed Cable Modem
D0CSIS 3.0
Link: https://www.netgear.com/home/products/networking/cable-modems-routers/CM700.aspx
Computer Specs:
See Attached Picture
Issue:
Since updating to the newest firmware, my router seems to restart on its own quite frequently (more than 10 times in the past two days).
Steps I've taken to try to resolve this issue:
- Step 1: Power Cycle Router
- Turn off router
- Unplug all cables
- Replug power and turn on for 2 minutes
- Replug everything else
- Step 2: Power Cycle Modem
- Same steps as "Step 1", but with the modem
- Step 3: Hard Reset Router
- Hold pin size button for 30 seconds
- Step 4: Hard Reset Modem
- Same as Step 3, but with the modem
- Step 5: Did following steps in this order - Step 2, Step 4, Step 1, Step 3
- Step 6: Reflashed firmware
- Downloaded and flashed via ethernet cable
- Step 7: Did Step 5 again
- Step 8: Changed Wi-Fi channels to least polluted channels
- Step 9: Did Steps 5-8 again
Someone PLEASE help. This has been such a frustrating two days of my router restarting on its own. Is this just a bad Firmware? Anyone else experiencing this? Apparently NETGEAR won't help since my technical support service is no longer available.
> I found out that when Spectrum came to set-up the internet, they set
> the router and modem for me with the power bricks swapped.Trust no one, I always say. According to their User Manuals:
CM700: 12VDC, 1A
R7500v2: 12VDC, 3.5AI would not be amazed if your R7500v2 was feeling a little starved on
a 1A power supply. Thanks for the report.
Sounds like you've hit most of the basics. You could try downgrading to a prior firmware to see if it brings the stability back. If it does, skip the most recent firmware. If it doesn't you could see if its possible a bad power supply causing the issues.
How you upgrade your FW is almost as important as what rev you run. Yes, follow plemans suggestion, and manually reflash, reset and confgure your device from scratch. Its perfectly acceptable to reflash the same version FW over itself, go back, forward, etc without ill effects. I haven't been following R7500v2 FW, so I cannot comment on which might be the most stable.
- jahn28Tutor
plemans and shadowsports
Thanks for the input. I downgraded the firmware back. So far so good, but I'm holding my breath at this point.
Hopefully Netgear will see this and double check their latest firmware.
Thanks!
- jahn28Tutor
Do you know if there's someone that knows the most stable firmwares? The downgraded version 1.0.3.38 had another episode of restarting.
Currently downgraded to 1.0.3.36 and testing it out for a while.
