j666gak
Dec 21, 2016Tutor
Nighthawk (R7800) - Unable to upgrade firmware
Hi,
I am currently on firmware version 1.0.1.16. When I press the button on the admin interface to check for firmware updates, it responds saying there are no updates available.
However, I decided to manually check myself and have seen v1.0.2.12 is available. Therefore I have downloaded and extracted IMG file and followed the article (http://kb.netgear.com/31477/R7800-Firmware-Version-1-0-2-12) but when trying tp apply the firmware it keeps returning error "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product". Once again, I downloaded the firmware v1.0.2.12 and tried to apply but get the exact same error.
Not sure what else to do?
A noob error on my part by the looks of it i'm afraid.... I have a D7800 and not the R7800. Although the only difference between the 2 is one includes a modem and the other is only a router.
So, it would appear Netgear are using two different versions of firmware for both the D7800 / R7800.
- j666gakTutor
Same issue with firmware versions listed below -
1.0.0.40
1.0.1.28
1.0.1.30
- mdgm-ntgrNETGEAR Employee Retired
You could try noting down your settings manually, doing a factory reset then updating the firmware, then after it has come back up on the new firmware doing another factory reset and then manually configuring your settings again
- j666gakTutor
I tried a factory reset just now, and then tried to upgrade the firmware.... but got the same error.
Thanks for trying, Is there anything else I can try?
- j666gakTutor
- JamesGLNETGEAR Employee Retired
Hi j666gak,
These are two different models with different hardware and software specs. It has different firmware.
