cap223's avatar
cap223
Tutor
Oct 01, 2016
Nighthawk R8000 Wired connection slower than modem direct connection
My R8000 is doing something strange. I just changed from TWC 300/20 mbps to AT&T Gigapower. With the new AT&T modem connected directly to the PC, I get 195 mbps down and 600 mbps up. However when I put the R8000 between the PC and modem, then I get 245/32. I've checked many different cables and even the 50 ft cables I have that are guaranteed Cat6. Results do not vary. What settings on my R8000 might be restricting the upload traffic?
I am testing this with no other devices connected to the router (wired). Also I've tried connecting the PC to the modem directly, while also having the router connected to the modem so that wireless devices are still actively connected.
  • In AP mode, the max speed between the WAN and LAN ports is pretty much what you are getting.  To avoid this speed penalty, use a LAN port.  Leave the WAN the disconnected.  Unfortunately, you will lose the ability to log into the router.  You'll have to reconnect the WAN port to log into it.
    Alternatively, you can disable AP mode and use the old school method for APs.  Disable the DHCP server and set a static IP address on the router.  This address must be in the subnet managed by the AT&T gateway but outside of its DHCP address range.  This IP address is what you'll use to log into the router.  Continue to leave the WAN port disconnected.
  • I will be doing that also, but the Netgear equipment is still seeing a major drop in performance from what I am seeing in the modem directly. That issue doesn't get fixed if my ISP increases my speeds more.
    • JDFlux's avatar
      JDFlux
      Tutor
      I am running a R8000 in AP mode behind my ATT Gigapower Router and 1000Mbps connection with everything turned off as suggested above. (QOS ect.) I am also expirencing a huge speed difference if I connect directly to the ATT Router or the R8000. All tests are done over CAT5 Ethernet. When I am behind the R8000 the best I can manage is: 480Mbps Down / 475Mbps Up. Behind the ATT Router I get 945Mbps Down / 948 Up. Obviously the R8000 is a bottleneck.
      • TheEther's avatar
        TheEther
        Guru
  • Given that you are not getting anywhere near 1000 Mbps while directly connected to the modem, you should sort that out with AT&T first. Once that's fixed, reinsert the R8000 and check the performance.
  • I have disabled the QoS but that has not solved the problem.
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi cap223,
      What is the exact subscription speed you have from AT&T?
      JamesGL
      Community Team
  • First, log onto the R8000 and make sure the following features are disabled.  QoS (but leave WMM on), port forwarding, MAC address clone, block sites, keyboard blocking and traffic metering.  All of these features disable hardware-assisted forwarding and force the R8000's main CPU to handle traffic.  Unfortunately, the main CPU cannot handle a full 1 Gbps of traffic.
    Second, with Gigapower, you should log into the AT&T gateway and enable either IP Passthrough (if you have a NVG599) or DMZ+ (if you have the Pace 5268ac) for your R8000.  This will bypass NAT translation for your R8000.  You will have to reboot the gateway for this change to take effect.
    • cap223's avatar
      cap223
      Tutor
      TheEther All those items on my R8000 are disabled. Any help on enabling DMZ+ on the Pace 5268ac? I've gotten as far as Settings>Firewall>Applications, Pinholes and DMZ. I've selected the r8000 to "host applications through the firewall". I don't know what exactly to choose at Step 2. But I don't want to mess with any settings I am not familiar with.
      EDIT: I see the third radio button to enable all applications (DMZplus)
