  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Routermania17,
    Try changing the channel of 5Ghz. If still the same, reset and reconfigure.
    • Routermania17's avatar
      Routermania17
      Thank for your email James GL. Do you believe a new firware could still be available soon ?
      • JamesGL's avatar
        JamesGL
        Hi Routermania17,
        The issue on both 5Ghz-1 and 5Ghz 2?
  • We upgraded a client to this firmware today and are also experiencing multiple and frequent disconnects on WiFi. We are going to have to roll back to a previous version.
    • LopezZondek's avatar
      LopezZondek
      Having the same issue. Resetting the router a couple of times a day to keep the wifi working. Is there any way to notify Netgear directly that this is an issue?
      Has anyone tried the DD-WRT firmware?
        Routermania17
        I tried to connect to the 5GHZ band  but it said wrong password even though it was correct..
        I tried to connect 4 times typing the password till it connected.. Anyone experiencing this issue ?
  • Hello All,
    Here is my issue, I have the latest firmware update and since that update I have had a terrible time staying connected or getting any of the download or upload speeds I am paying for.  I had an Xfinity guy come out and dissconnect the router and test the modem and am getting on avearge download speeds of 250mbps and uploads of around 11 - 12mbps.  Once we connect the router it drops to 40mbps - 60mbps,
    I have reset the router, I have disconnected everything and redid set up and still the same issue.  I have talked a a few trusted colleauges and they mentioned the latest update Version:1.0.3.54_1.1.37 is causing these issues and I need to rollback to the previous firware release.
    Any advice or reccomendations would be very helpful. Thanks
    Brian
