chopin70's avatar
chopin70
Virtuoso
May 28, 2016
Nighthawk rooters and https admin GUI
Hi,
Why we still don't have any option to access GUI management through https and disable http, either for remote management and for local management
Using http any being impossible to disable it is a big security issue, even through LAN
  • Are you able to access your router remotely using http? I always get an error if I try.
  • I never tried remote, but through LAN. Only option is http
    In manuals and options, i only see http for remote, with option to change port, which is kidding as of security
    Even locally, a bad site can sniff the pass by redirecting a simple malicious script to the http admin gui. If you saved pass, it can sniff it
    • TheEther's avatar
      TheEther
      Guru
      Remote management is definitely https, not http.  The R7000 manual has a typo on page 180.  If you look on the configuration screen on page 179, it's correctly shown as https.
      The local connection is still http, so you still have a valid point, here.  You can vote for adding https here.
      • chopin70's avatar
        chopin70
        Virtuoso
        I see nothing relevant P180 !
        Remote management is in P159-160
        It definately shows using http through a custom port, no SSL through 443 port
