TrickyWoo's avatar
TrickyWoo
Nighthawk x10 ad7200 to Nighthawk ax12 ax11000 setting transfer
Hello having used the X10 nighthawk for the last 3 years, I want to now set up a new AX12 nighthawk as the main router from a virgin hub 3 without loosing all my settings and having to re-configure devices like Arlo cameras onto a new network. Is this possible please as I would also like to then use the x10 as a secondary router in the house but I think I should be ok with setting that up once the AX12 is in place. Just do not want to loose current network settings in the process of swapping. I am fairly novice at doing this too apart from you tube guides which do not answer transferring network details to the new ax12.
  • plemans's avatar
    You shouldn't use a backup configuration from one device for a different one because of differences in hardware.
    What you can do is use the same ssid/password on the new device and the wireless devices should auto-connect.
    If you have any port forwarding rules/ip reservatios, write those down or snap a screensnip/picture.
    • TrickyWoo's avatar
      TrickyWoo
      Hello again,
      that is kind of what I mean't, transferring the SSID... but for a novice and none IT person I would have no idea how to do this despite the nighthawk app saying this is possible..
      it will be a case of derrrrrrrr...... I have no idea.. but thank you for responding
      • plemans's avatar
        Its not hard.
        Simply write down your current ssid and password. Then during setup of the new router, enter the same ssid/password as the old one. There'll be an option during setup to enter your own ssid/password and that's when you do it. Or if you miss it, you can always log into the router afterwards and change it.
