dabears
Mar 08, 2017Star
NightHawk x10 r9000 wifi dropping issue
Hello,
I just purchsed Netgear Nighawk X10 AD7200 R9000 wifi router last week and i installed the latest firmware version 1.0.1.36 and I am having issue where the WIFI SSID Drops totally from the network and when you go back and try to connect any devices, you can't see the SSID. Its like it doesn't exist on the network. The only solutions is that i have to reboot the router and the SSID and connections are made again successfuly and everything works as it should. This happens to all across the board frequency's 2.4 GHz, 5 Ghz, or the new 60 GHz. I would like to know if any one else is having similar issue with the router or if there is a bug on the new firmware version what is the fix for it? I also did change the channels on 2.4 GHz and 5 GHz. 2.4 GHz on channel 11 and 5 GHz on channel 161. Any help would be apperciated or else only resort for me is to return the router within 14 days and get different option.
Thank You
FYI to all:
I called Netgear support to tell them flashing the firmward didn't work, so they are going to replace the unit. I exeplained to the representative that there were mutliple users complaining of the same issue on the community site, and he told me that the team that handles the advanced issues (tiger team, he called it) told him to replace the unit. There wasn't anything else he could do.
Maybe if the next unit has the same problem they will finally engage engineering, as no one seems to be watching this community site.
- rrnycApprentice
I think everyone having WiFi issues should look at this:
https://www.cnet.com/how-to/how-to-keep-google-home-chromecast-from-killing-your-wi-fi/
- bkfosterAspirant
I don't have any Google Home or Google hardware products on my network, but I do have two Amazon Echos and a couple of TPL smart televisions that accept Chromecast. I wonder if that would be it. Strangely, though, they don't effect my R8000.
- rrnycApprentice
It has to be related to the Chromecast feature. There are way too many users experiencing WiFi issues with some Netgear routers. Apparently, not all routers are affected.
