jgeorge116's avatar
jgeorge116
Nighthawk X6 AC3000 (R7900) Speed Not Reaching 500mbps
Hello
I am located in Texas, USA.
I have the NETGEAR Nighthawk X6 AC3000 (R7900). I recently updated my internet speed from 300mbps to 500mbps.
When I tested my hardwired internet to my desktop, I am only getting 340mbps. The signal chain was Modem -> Nighthawk Router -> Trendnet Switch -> Hardwired Desktop PC.
I started troubleshooting and then connected the modem directly to my deskop. This setup gave me the correct speed of 500MBPS.
 I then eliminated the switch and went modem-> nighthawk router-> hardwired desktop PC. The issue presented itself again and only getting ~300mbps. The weak link here is the nighthawk router.
Note: I already confirmed my cables are all working. They are all eitehr Cat5e or Cat6.
Modem Model is Arris Surfboard SB8200
Can someone point me to how I can start troubleshooting the router? What settings do I need to start looking at?
  • plemans's avatar
    Since you upgraded the speeds, try a factory reset.
    During the reinstall, make sure to leave qos, access control, traffic monitoring, and parental controls all disabled.
    • jgeorge116's avatar
      jgeorge116
      I want to try and avoid a reset for now.  Is it really the only option when once upgrades speeds?
      I checked my current setting below.
      QoS is NOT enabled.
      Access Control is NOT Enabled
      Traffic Monitoring: I don't see a specific setting for this but all traffic is allowed at all times
      Parental Controls is DISABLED
      Kindly let me know if you have any other ideas...
      • FURRYe38's avatar
        Has a power off for 1 minute then back ON with the ISP modem and router been performed?
        Turn off and unplug modem.
        Turn on computers and rest of network.
        If this fails, you'll need to factory reset and setup from scratch. Do not load a saved configuration from file.
