LeeGillie's avatar
LeeGillie
Nighthawk X6 AC3200 Smart WiFi Router (R8000) DNS ISSUE
My router firmware version is: V1.0.4.84_10.1.84
I am having intermittent issues with DNS. I see this in a web browser. When I first go to a site it displays not available. but then a couple of seconds later it displays. It appears the first failure is because of a site not found error. For sites I go to frequently they always come up quickly. My dns server for my windows 11 desktop is my Netgear Nighthawk X6 AC3200 Smart WiFi Router (R8000). IPCONFIG /ALL show "DNS Servers: 192.168.1.1" My desktop is direct wired to it. I have tried 2 different DNS settings on the router, but it seems to make no difference. 1 is to get automatically from ISP, and the other is to manually set 8.8.8.8 and 8.8.8.4.
Using Fiddler to try to understand this. First time I try to browse to dji.com...
GET http://dji.com/ HTTP/1.1
Host: dji.com
Proxy-Connection: keep-alive
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
Accept-Encoding: gzip, deflate
Accept-Language: en-US,en;q=0.9
The response is...
HTTP/1.1 502 Fiddler - DNS Lookup Failed
Date: Fri, 09 Jun 2023 15:48:57 GMT
Content-Type: text/html; charset=UTF-8
Connection: close
Cache-Control: no-cache, must-revalidate
Timestamp: 08:48:57.535
[Fiddler] DNS Lookup for "dji.com" failed. System.Net.Sockets.SocketException No such host is known
Then I immediately browse to dji.com again, and it connects completely without issue.
I am highly suspicious of the DNS provided by my router in this.
FWIW - This is my home computer, not on a domain, but rather a workgroup.
What may be causing this intermittent issue, how can I diagnose it, and more importantly how can I fix it?
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What browser are you using? Happens in different browsers?
    What happens if you enable IPv6 (Auto) on the router, save and apply, then reboot the router and power cycle the ISP modem/ONT and all connected devices. Be sure to clear all browser caches as well.
    • LeeGillie's avatar
      LeeGillie
      I have xfinity/comcast as my ISP. I use my own xfinity approved modem:
      The modem is: ARRIS Surfboard S33 DOCSIS 3.1 Multi-Gigabit Cable Modem | Approved for Comcast Xfinity, Cox, Spectrum & More | 1 & 2.5 Gbps Ports | 2.5 Gbps Max Internet Speeds | 4 OFDM Channel
      https://www.amazon.com/gp/product/B08FMSC5WZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
      Cable is CAT 6.
      Doesn't matter which browser. I am a software developer, and I see it my own applications connecting to the outside. Sometimes after DNS resolution failure, I run my program again, and it works perfectly.
      • FURRYe38's avatar
        There is a long standing DNS issue on NGs R series routers. Been on going since and we have sent this to NG for review. Others came up with a work around to enable IPv6 (Auto) seems to help for most users. Something to try.
        No idea if or when this will be finally fixed. We don't get that info here.
  • This had hit the nail on the head, exactly same issue. I had spent weeks trying to sort this issue out. Unsure of the dark magic behind it but thank you FURRYe38 for your wisdom across the many related articles. For numpties like me that need pictures here is where you can enable IPv6 on your router, you should use Kitsap 's useful .PDF to fill in the gaps.
