Dayhiker4k
Jul 10, 2017Tutor
Nighthawk X6 R8000 AC3200 Questions: Mode & QoS
I just listed a post: "Web-based setup shows no Internet." This post is a question about setup. I thought they might me related.
(1) I see it is set up in Access Point Mode. Is AP the correct Mode or should it be in ROUTER Mode?
(2) Should I be using QoS? I see it's not available the way I have it set up.
My ISP is Comcast.
The Firmware version is: v1.0.3.46_1.1.32; and the Windows version is: Windows 10 64 bit, version 1703 (?). The version Microsoft recently released.
If anyone can help this networking novice, I would appreciate it.
My ISP is Comcast.
Hi Dayhiker4k,
Access the UI of the router and go to advance settings under advanced tab. Select wireless AP then uncheck the wireless AP button.
- netwrksMaster
In Access Point mode, it's common to see No Internet, as the WAN port is not connected to the WAN, but a Base router. Can you get out to the Internet? Did you configure it in AP mode, or did it switch on its own?
EDIT: What model of Comcast device do you have?
Hello,
Yes, I can get to the Internet. It configured itself to Access Mode. After I left the post yesterday I did a Google search. I suspect it was because of this Comcast device. It's an Arris Touchstone TG862 Telephony Gateway. It's a cable modem with WiFi built-in and that's how I get phone service. The P/N is TG02DH7862CT.
How do I reconfigure as a router? Also, how does QoS work and do I need it for my home network? I rent out rooms in my house for extra income, so it would be nice to have additional control of my network if it's not too complicated to set up.
Thanks for the help!
- JamesGLNETGEAR Employee Retired
Hi Dayhiker4k,
