Imperialsalsa
Aug 07, 2023Aspirant
Nighthawk x6 r8000 Wifi issue
I have a Nighthawk x6 r8000. Firmware is up to date. Using starlink.
Wifi is showing off in the netgear router menu but the physical lights on the router are lit up.
I have reset the router
I have factory reset the router.
I have physically press the wifi button on/off
I have changed the wifi channels.
I have changed the password and security type.
Wifi signal will not turn on or show on any devices.
I even changed where i plugged the router in.
Any ideas? or did my wifi just go out. Physical connection works. Only nonworking thing on device is the wifi signal
When you pushed the wifi on/off button, did you hold it for at least 2 seconds?
- ImperialsalsaAspirant
Yes
- DexterJBNETGEAR Moderator
Hi Imperialsalsa , if you're still experiencing the issue. We recommend that you reach out to our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/about/contact-us/
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
NETGEAR Team
