Dr_Dan's avatar
Dr_Dan
Nighthawk X8 R8500 Rattle - How to Open Box
My router is working fine, but when I picked it up and moved it I noticed a rattle. I think something small may have fallen into the box. I found 2  obvious hex screws on the bottom, but I'm sure I must be something else to open the box. I'd appreciate any help.
  • There are more screws on the feet.
    Remove the rubber feet in each corner and you'll see more screws.
    • Dr_Dan's avatar
      Dr_Dan
      I already looked there. I found a video for the x6, but it's a different box and doesn't apply.
      • doraemon's avatar
        doraemon
        Prodigy
