helpmeplease12
Dec 13, 2021Tutor
No internet after firmware upgrade and factory reset R7000
Hello!
I recently upgraded my R7000 to the latest firmware (1.0.11.128) as of last night and per recommendations, performed a factory reset on the router, including powering off my modem, waiting for that to restart and then booting the router back up.
After resetting the router, I have no wifi. All lights on the router are solid white, making it seem like there should be a wifi connection. My phone, laptop, and smart TV can all “connect” to the wifi, but when trying to load something, all three say there is no internet connection.
I do not have the ability to do a hardwire test to the router.
Please help. I am at the end of my rope.
Update: tried connecting through the NightHawk app on my phone and it says the router is disconnected.
Update 2: all lights on the router remain solid white. The app is saying it can no longer find my router.
Push and hold the wifi on/off button for 2 seconds.
sometimes that gets hit while people troubleshooting devices.
- Thank you for the reply! I just tried turning the wifi button off and back on and there was no luck. Cannot even find my network in my wifi settings on my iPhone now.
Know anyone with a laptop/pc you can plug into the router to check if its working as well as what its ssid/password is?
They also make usb/ethernet adapters.
When you reset, did you push and hold reset for 7-15 seconds while powered on?
If so, the wifi should be the default ssid on the sticker.
