_Tru_'s avatar
_Tru_
No Power Nighthawk R7350
Router has been getting slower over the past few weeks. I confirmed it wasn't my cable modem. I come home today and saw that the router is on but only see a solid orange power light. I've tried resetting to factory, unplugged it for a few minutes with no change, the power light stays a solid orange. There's no activity or power coming from the Ethernet ports either. Product is still under warranty, but Netgear gives me no way to file a claim, only send me to the community.
  • michaelkenward's avatar
    michaelkenward
    A bad sign. Usually means broken firmware, or it could be the power adapter.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Troubleshoot With the LEDs.
    I don't know how you are trying to make a claim.
    Start the RMA process by checking MyNetgear.
    How do I request a Return Material Authorization (RMA)? | Answer | NETGEAR Support
    • _Tru_'s avatar
      _Tru_
      I tried your link and the website kept crashing. Came back a few hours later and was able to put in a request. Thank you!
  • FURRYe38's avatar
    Try a different power adapter to test.
    Try here? https://my.netgear.com/support/contact.aspx
    DarrenM
    • _Tru_'s avatar
      _Tru_
      I have an older Netgear router before this one with a known working power adapter (exact same power output and amps), only to get the same results.
