nyvagenealogy
Jun 16, 2021Aspirant
no wifi connection
nighthawk r6400v2
1. no wifi
can connect via ethernet cable BUT NO WIFI can not connect table or laptop via wifi
2. bought a brand new netgear to fix #1
it had NO INTERNET AND NO WIFI (ax1800)
so i reinstalled the nighthawk and have internet but NO WIFI.................
I HAVE reinstalled and uninstalled for 7 days
NONE OF MY WIRELESSS devices CAN SEE............ R6400V2 none
and the new one is AX1800 and it had NO INTERNET AND NO WIFI when hooked up
would someone PLEASE tell me what to do........
ALSO my cable company says because my phone and tv, and internet with ethernet ARE WORKING
it's not their products.
> the cox cable guy came in and pushed the ON wifi button, that i did
> not know was NOT A LIGHT, but a button that lights up> [...] Get the User Manual (at least). Read. Look for the
> LED descriptions and "Troubleshoot". Pay particular attention to the
> "WiFi On/Off button with LED". Did you press it? Further reading
> might not hurt, either.It's a miracle! Who'd've guessed?
> nighthawk r6400v2
Firmware version? Connected to what?
> laptop via wifi"can not" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
might not hurt, either.> 2. bought a brand new netgear to fix #1
The non-psychics in your audience might be unable to guess what it is
or what you did with it.> it had NO INTERNET AND NO WIFI (ax1800)
"AX1800" is a speed, not a model number. Look for "Model" on the
product label. I'd guess that there's a User Manual for it, too.> would someone PLEASE tell me what to do........
You might try this radical concept which works for some people:
https://en.wikipedia.org/wiki/RTFM
Right. Wired-good, wireless-bad is a local-to-you problem.
- nyvagenealogyAspirant
cisco modem to netgear router,
i get internet via ethernet but no WIFI
> cisco modem [...]
Not a very detailed description of anything. Has it a model number?
I got that much _before_ I asked any questions. Plenty of other
questions still waiting for answers. Look for "?".- nyvagenealogyAspirant
n300 wnr2000v5
the cox cable guy came in and pushed the ON wifi button, that i did not know was NOT A LIGHT, but a button that lights up
and all was fixed,
except now i have 2 alexas and one works and one says i have no wifi...........................
just wanted to say that when i received email replies to this message and tried to follow through, i received authentication failed
messages,
just want to mention that,
thanks
