Mnmsprague1779's avatar
Jun 21, 2016
No wifi on the third floor
I just purchased a nighthawk r7000. My modem is currently located in the basement and the router is there too. I cannot bring it up to the main floor without re-wiring. What are my options to get wifi on the third floor? I don't even get a week signal up there.
  • Retired_Member's avatar
    Retired_Member
    Jun 21, 2016
    You could try power line adapters. You'll never have decent thoughput.
  • Your router should sitting on the third floor or one floor down from there. If you can't relocate router, seek another means with
    AP or repeater.
    Retired_Member
