anario's avatar
anario
OpenVPN error
Hi Guys,
Could you please suggest me solution of how to establish connection between my remote machine and router.
I added keys to /etc/openvpn/  dirrectory
#openvpn --configure client2.conf
i got this error msg. ERROR: Linux route add command failed: external program exited with error status: 2
I tested on two different OS .. centos and ubuntu. on both i got same error.
Just wanted to add ... i cn connect from windows os and mac without any issue.
Thanks in advance
  • Thank you ElaineM
    so now i'm able to connect, but i cant forward vpn connection in our office, also i can't ping from remote network my local machines is there any solution ?
    • anario's avatar
      anario
      Thank you ElaineM
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        What do you mean you cannot forward VPN in your office?
        Can you provide a network diagram?
        If you're unable to ping, check for any firewalls.
