c3collins
Feb 21, 2022Aspirant
Outgoing eMail on Port 587 Blocked - Nightwawk R6700
Since Installed my own modem (Arris surfboard) and Nighthawk R6700 router, I have two email accounts that receive email but cannot send outgoing mail. The outgoing port is 587. I have other email (gmail accounts) that are having no problems sending and recevieing email. Is there a setting that needs to be changed on my router to allow outgoing email from port 587?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?All email settings would be done at the email client on the devices. Routers don't support any email client configurations nor usually won't interfere with email services. Unless you have Armor or Smart Partental Controls enabled then these could cause some problems.
- c3collinsAspirant
The firmware version is V1.0.4.122 and the modem is Arris Surfboard SB6190.
Any thoughts would be appreciated.
FURRYe38 wrote:What Firmware version is currently loaded?
- KitsapMaster
Three other things that would be helpful: Who is your ISP? Are you on Windows? (If yes, what version), and what is the name of the client application you are using to access your e-mail?
