oppeku
Jun 13, 2026Follower
Password change on Nighthawk AC2300 Smart WiFi Router (R7000P)
How do I change the password for the Nighthawk AC2300 Smart WiFi Router (R7000P)?
Might start socking away a little money here and there. That R7000P was a decent router. But that was over a decade ago. While it still works for most situations (and is pretty solid), its also getting a bit older, doesn't get updates anymore, and is several generations behind.
But props for getting all you can from it!
There are three passwords on Netgear routers:
- The credentials required to use the WiFi network
- The credentials required to access the router web interface
- The credentials required to use the Nighthawk smartphone app
Might start by looking at the User Manual:
https://www.downloads.netgear.com/files/GDC/R7000P/R7000P_UM_EN.pdf
