Salakos
Jun 11, 2017Tutor
Plex not showing movie images R9000 x10 or scanning media files for more than one library
I saw that someone previously had a similar, if not the same issue. Their write-up is as follows: " Just setting up Plex on my R9000, connected USB 3 thumbdrive (32GB), and usin g my NAS as storage ...
- Jun 11, 2017
NTFS is more universal. Let us know how it goes. Just use a Windows PC and format for NTFS using defaults.
Jun 11, 2017Guru - Experienced User
OS Journaled is a Apple OSX formatting. Doesn't work in WIndows. I presume they were operating in OSX for there problem.
Have you formatted NTFS?
- SalakosJun 11, 2017Tutor
I have not, yet. I will begin to reformat the USB to NTFS, if you think that will help.
- FURRYe38Jun 11, 2017Guru - Experienced User
- William10aJun 11, 2017Master
Thats the problem with Apple with a different format for the harddrive then Windows and Luix with its own too bad there is not standard that would the readyshear work across a network with many different make of computers and devices that would help a lot.
