scouzi66's avatar
scouzi66
Port forwarding to a VPN client
I enabled VPN access to my R7000 running the latest formware level. Port forwarding to a VPN client connected does not work. Is this supported? I forward the port to the local IP address provided to the client. Internally I can access the VPN client from other machines on local network. Externally, I cannot reach that VPN client when forwarding a port to it.
  • Hi scouzi66,
    If you will use it on a PC, you should use TAP and TUN is for mobile or smartphones.
    TUN mode - 12973 (for smartphone)
    TAP mode – 12974 (for PC)
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi scouzi66,
    1. What is the software of your VPN?
    2.  Where is the VPN server connected?
    3. Make sure the port forwarded is the correct port for your VPN.
  • JamesGL's avatar
    JamesGL
    Hi scouzi66,
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    • scouzi66's avatar
      scouzi66
      Upon further investigation ...
      The port is indeed forwarded to the client. However, since source IP address (outside)  is not natted to the LAN side of the the NetGear router (LAN side of VPM server), the VPN client responds back through it's own WAN interface rather than it's tun0 interface which the original request came through.
      It would be nice if a feature was available to SNAT external IPs (ie public) to a LAN side IP address with VPN server service.
      • scouzi66's avatar
        scouzi66
        Just a clarification to make ..
        It's a TAP on the client and not a TUN.
        Here is my client config file as generated by the router config
        client
        dev tap
        proto udp
        remote xxxxxxx.mynetgear.com xxxxx
        resolv-retry infinite
        nobind
        persist-key
        persist-tun
        ca ca.crt
        cert client.crt
        key client.key
        cipher AES-128-CBC
        comp-lzo
        verb 5
