Billabong12789
Jan 07, 2015Initiate
Problem with Wifi on all Apple Devices on my Network
Hello Everyone, A few days ago I started to experience WIFI issues on my Home Network with only APPLE DEVICES We have One MacBook Pro 2012, two IPhone 6+s and also a windows PC all running WIFI on a N...
- Jan 10, 2015Hi everyone I believe, my problem is FIXED. I had IPV6 disabled. I enabled it set it to auto detect and it has seemed to fix the problem. As far as WMM is concerned my IPHONE 6+ will not work correctly without it enabled. Very disappointed with these recent apple products never been a fan but the rest of my family is. I hope this HELPS
bugmenot2
Jul 29, 2016Apprentice
I had a similar issue with a Netgear wndr3700v2 with a Arris sb60141 cable modem, with an Xfinity connection. The ipv6 tip did not work, but setting the router to be the DHCP server, instead of getting up addresses from Comcast did.
