Billabong12789
Jan 07, 2015Initiate
Problem with Wifi on all Apple Devices on my Network
Hello Everyone, A few days ago I started to experience WIFI issues on my Home Network with only APPLE DEVICES We have One MacBook Pro 2012, two IPhone 6+s and also a windows PC all running WIFI on a N...
- Jan 10, 2015Hi everyone I believe, my problem is FIXED. I had IPV6 disabled. I enabled it set it to auto detect and it has seemed to fix the problem. As far as WMM is concerned my IPHONE 6+ will not work correctly without it enabled. Very disappointed with these recent apple products never been a fan but the rest of my family is. I hope this HELPS
ppLuiGui
Jan 09, 2015Aspirant
Did you fix the issue? i have the exact same problem, i have several devices connected over wifi with no problems, but my Macbook pro (mid 2014) and my Iphone 6+ well i sometimes cannot connect to appstore, youtube videos stop playing and stuff like that its annoying!, if i connect my Macbook over ethernet then i have no problems any suggestions?
