softerist
Feb 07, 2017Apprentice
Problems installing and running Plex Media Server - button "Open PLEX" greyed out
Hello, Today I've got a brand new router, and I cannot Open Plex Server from Genie. The button "Open Plex" is greyed out. I tryed with two external devices to install it, with an WD My Book New ...
- Feb 10, 2017
Well I have to talk on the phone with a level 2 suppot, he made a remote connection in my pc, downloaded the beta firmware and installed in my router.
After this procedure, I have PLEX button now.
Thank you all for your replys.
clithes
Feb 07, 2017Prodigy
- WacasFeb 07, 2017Tutor
Re: R9000, "Open Plex" is grayed out
2017-02-08 11:53 AM
I am having the same problems i have tried to contact netgear and cannot get through the company i bought the router from says they cant help me ........i have tried all the solutions except for the beta firmware but as mentioned cannot get on to Netgear i am going to reistall the older firmware and see if i get lucky from that
i do want to keep this unit but plex is the deal breaker - softeristFeb 07, 2017Apprentice
There is no Library Folder on the External Drive, so this solution doesn't apply for me.
- softeristFeb 08, 2017Apprentice
I've tryed everything. It's not working, I need this fixed please!!!!
Nighthawk R9000 - Plex Button Greyed Out - not working
- WacasFeb 08, 2017Tutor
Contact Netgear support they are well aware of this issue they will give you a link for this firmware .......you will have to sign up for using beta firmware that way you will still be covered under wty if something happens the whole process took 20 to 30 mins over the phone best to call is when you are at your computer where the router is
