softerist
Feb 07, 2017Apprentice
Problems installing and running Plex Media Server - button "Open PLEX" greyed out
Hello, Today I've got a brand new router, and I cannot Open Plex Server from Genie. The button "Open Plex" is greyed out. I tryed with two external devices to install it, with an WD My Book New ...
- Feb 10, 2017
Well I have to talk on the phone with a level 2 suppot, he made a remote connection in my pc, downloaded the beta firmware and installed in my router.
After this procedure, I have PLEX button now.
Thank you all for your replys.
softerist
There is no Library Folder on the External Drive, so this solution doesn't apply for me.
softerist
Feb 08, 2017Apprentice
I've tryed everything. It's not working, I need this fixed please!!!!
Nighthawk R9000 - Plex Button Greyed Out - not working
- WacasFeb 08, 2017Tutor
Contact Netgear support they are well aware of this issue they will give you a link for this firmware .......you will have to sign up for using beta firmware that way you will still be covered under wty if something happens the whole process took 20 to 30 mins over the phone best to call is when you are at your computer where the router is
- softeristFeb 10, 2017Apprentice
